Problem with PLA
Hello, I have a problem with printing, after about 80% of printing, in the middle of printing the filament is terribly deformed, as if it was melting. and I don't know what the problem is because it looks good on the outer edges, I print at a temperature of 200 degrees Celsius, but I increased and decreased the temperature in the range of 195 and 215 degrees and the table temperature was 60 degrees and I don't know what to change to make the print look good.
Best Answer by czarnyjerem:
Hello again, the fault lies with the .stl file, you can close the post.
Postato : 16/12/2023 11:26 pm
Topic starter
answered:
RE: Problem with PLA
Postato : 23/12/2023 6:13 pm
