Print TPU in Prusa Enclosure, and any suggestions for profiles?
Wayne
(@wayne-9)
Mitglied
I have some Eryone TPU filament coming, and I have some questions about printing with this.
My mk4 is in an enclosure, and I generally use the spool mount with the boden tube for PLA and PETG. Will this work well with TPU, or should I mount the filament outside the enclosure and remove the boden tube for this run?
Secondly, does anyone know a decent filament profile for the Eryone TPU at https://www.amazon.co.uk/dp/B07WFJN6FG?psc=1&smid=A2VIQTBBRTKZCB&ref_=chk_typ_imgToDp?
Thanks,
Veröffentlicht : 17/06/2024 8:52 am
wsar
 wsar
(@wsar)
Mitglied
RE: Print TPU in Prusa Enclosure, and any suggestions for profiles?
I removed the little cover at the top of the enclosure and put the filament direct to the extruder. This with a spool holder. With that everything went well.
Veröffentlicht : 27/09/2024 6:01 pm
Brian
(@brian-12)
I print TPU 95A in an enclosure regularly without issue.
If it's a long print don't go crazy with retraction or you will have issues when the enclosure gets hot.  The default profiles in PS have worked fairly well for me with only really tweaking temperature.
Veröffentlicht : 28/09/2024 12:20 am
Wouter2020
(@wouter2020)
Mitglied
I know the topic is old, but still wanted to share my (bad) TPU experience and solution.
I use an Prusa MK4 with enclosure. I added a closed box on top of the prusa to keep te filament dry. The filament runs through a (rather long) tube to get to the extruder. Works perfectly with PETG. No issues at all.
However, when using TPU, the PTFE tubing cause a lot of friction. Because of this, when the TPU is pulled on by the extruder, it elongates and (like any elastic) it pulls back. For my situation, this caused the filament to be pulled from the extruder and it showed a message "replace filament" every X minutes.
Removing all the PTFE tubing for TPU printing and reducing the friction along the line fixed the issues.
Veröffentlicht : 30/05/2025 8:21 pm
