Pla prints with large supported area has Bad surface finish
Alaric M
(@alaric-m)
Mitglied
Well, as the title implies, i am trying to print this part out of PLA. (forshape ecoPLA)
I have an enclosure and a filament dryer, and the moisture is about 44% in both of them.
I tried changing the top contact Z distance (from 0.25 to 0.1 mm), but this only made them harder to remove.
Does anybody have an idea on how i could get better surface finish ?
Thanks for your answers.
Veröffentlicht : 08/11/2024 2:15 pm
Alaric M
(@alaric-m)
Mitglied
RE: Pla prints with large supported area has Bad surface finish
For reference, here is the cad model and the cross section to give you a better idea  :
Veröffentlicht : 08/11/2024 3:10 pm
Did the printer generate supports?
Veröffentlicht : 08/11/2024 3:35 pm
Alaric M
(@alaric-m)
Mitglied
Yes it did
Veröffentlicht : 08/11/2024 3:53 pm
Alaric M
(@alaric-m)
Mitglied
Also, i made sure to check and the supports stayed attached to the build plate and there were no layer shifts whatsoever
Veröffentlicht : 08/11/2024 4:10 pm
It would probably print better tilted at 45°, you will still need support.
Veröffentlicht : 08/11/2024 4:48 pm
John
 John
(@john-6)
Some designs are very difficult. I would print in two parts ( Centre disk and the rest with key lugs) press fit - and glue if needed
i3 Mk3 [aug 2018] upgrade>>> i3MK3/S+[Dec 2023]
Veröffentlicht : 09/11/2024 1:46 am
