PETG support is damaged by the nozzle.
As you can see on the photo a part of the support is damaged.
Using Prusa PETG and Prusa slicer 2.6 with default settings for Prusa PETG.
How can I provide this damaging of support structures? This print job takes about 8 hours...
Respondido : 06/07/2023 1:27 pm
Topic starter
answered:
RE: PETG support is damaged by the nozzle.
Maybe its better to use pattern "Rectilinear grid" instead of default "Rectilinear" ?
Respondido : 06/07/2023 1:35 pm
Are you using the Input Shaper firmware or the original 4.7..2 ?
Respondido : 11/08/2023 4:40 pm
Topic starter
answered:
I'm using 4.7.0 because higher firmware versions can cause a shift during the print job.
Since I added the Silicon Hot-End Socket most problems are solved.
Without silicon Socket the Hot-end grabs a lot of filament and will cause dropping clumbs which is probably also the cause of the support wrap.
Respondido : 11/08/2023 5:27 pm
