PETG not sticking to textured sheet?
JohnFajardo
(@johnfajardo)
Miembro
Hi all,
after printing with no issues for about a month, I suddenly cannot print anything in PETG since the first layer is not adhering to the sheet. Is there any setting I can change?
Respondido : 12/09/2023 9:03 pm
1 les gusta
Hello
(@hello)
RE: PETG not sticking to textured sheet?
Posted by: @oldschoolkratos
Hi all,
If you have printed alot with it the texture can ho down try contact prusa if the sheet is less then 1 year old
Respondido : 12/09/2023 9:34 pm
Prusa considers the steel sheet consumables so they won't do anything.
The usual first try is to clean the sheet thoroughly with dish washing soap and plenty of hot water, and after drying it wipe it with 90+% isopropyl alcohol.
Did PETG print okay for you before? On my Mk4 I need to manually adjust live Z at the start of the print by -0.025 to get good adhesion.
Respondido : 12/09/2023 9:39 pm
Hello
(@hello)
They do if it's less then 6 months old
Posted by: @fuchsr
Respondido : 12/09/2023 10:15 pm
JohnFajardo
(@johnfajardo)
Miembro
Thank you guys!
The sheet is new (MK4 kit received less than two months ago). I will try the dish soap tip after this print is finished. For the current print, I lowered the Z offset by -0.5 and it looks a bit better. Perhaps it was too much, but my supports still look atrocious.
EDIT: At least now I get adhesion!
Esta publicación ha sido modificada el hace 3 years por JohnFajardo
Respondido : 12/09/2023 10:17 pm
Hello
(@hello)
Posted by: @hello
Posted by: @fuchsr
AND as long as there is no dents
Respondido : 12/09/2023 10:20 pm
JohnFajardo
(@johnfajardo)
Miembro
I'm sorry for the blurry photo, it's hard to focus when it's printing. Does this mean I lowered my Z offset too much? In my previous post I said I wen't down by -0.5, but I just checked and it was actually 0.05
Respondido : 12/09/2023 10:47 pm
Ckobar
(@ckobar)
how do you offset the z value ?
( funny i just wanted to open a toppic with the same question.)
PETG on the satin sheet works fine for me. (prusa PETG/extrudrPETG 0,4 nozzle, standard settings)
But on the textured sheet  most of the times the prints gets shoved around a short time into the print.
Respondido : 13/09/2023 10:57 am
JohnFajardo
(@johnfajardo)
Miembro
Printer settings > General > Z offset.
Respondido : 13/09/2023 12:20 pm
As soon as the print starts, hold down the button on the LCD display, which brings up the Live Z adjustment option
Respondido : 13/09/2023 12:57 pm
Ckobar
(@ckobar)
I just finished my enclosure the other day. And did a test-print with PETG on the TXT-Plate. Temp inside the enclosure around 30-35°.  It worked great. No brim etc. necessary.
For reference i did a second print, opened the doors and turned on the fan. After a few layers the print came off the bed.
So, in my case. It has been the ambient temperatures and unwanted drafts that were causing the problems when printing "outside"
Respondido : 21/09/2023 7:44 am
HikerGlenn
(@hikerglenn)
Cleaning with soap and hot water followed by a very hot rinse did the trick for me.  I had this problem when I flipped my sheet over after wearing out the first side.
Respondido : 07/10/2024 3:27 pm
Antimix
(@antimix)
I am having this problem suddenly with PRUSAMENT PLA on the satin plate.
This summer all was perfect, but now, with inside temperature around 20°C the PLA bend at bed level after having printed around 1 cm of print, and detaches.  It seems like the new filament products are designed to move from an open 3D print to a closed chamber to be printed well.
Respondido : 13/10/2024 12:04 pm
