[Rozwiązany] Nylon versus supports
zaitcev
(@zaitcev)
To be brief, supports are very difficult to remove when printing in Nylon. This is a pure Nylon, not the more common filled Nylon with carbon or glass. I use Creality filament.
I am already using  Top contact Z distance = 0.2, and  Top interface layers = 2  in the PrusaSlicer.
Note that because Nylon is very strong, I am able to use electrician's pliers to grab whatever sticks and rip supports away without damaging the print. However, this does not work inside small cavities, and I still have the interface layers attached.
How do you deal with it?
This topic was modified 2 years temu by zaitcev
Opublikowany : 16/12/2023 7:45 pm
zaitcev
(@zaitcev)
RE: Nylon versus supports
We found that NylonX can be printed. It is unfortunately filled with CF, so there's no solution for a pure PA6. But it works for us.
Opublikowany : 13/06/2024 10:40 pm
