Multi color print without MMU
strjan
(@strjan)
I dove into printing with multiple colors, and I came across some issues or maybe misunderstanding (I have the printer for about a week...).
The aim is to have a text in the first layer of the print. I have the newest PrusaSlicer (2.9.0) and firmware (6.1.3). I added the text object the slicer, set its height to the height of one layer. I selected 2 extruders in Printer setting and associated the object and the text to the different extruders. After slicing, it shows the colors correctly. I have also added M600 to "after tool change" section of custom G-code (it doesnt ask for filament change without it). The slicer also add an extra object, I suppose that is the wipe tower.
Already here, there is first issue: slicer wants to do 2 tool changes, even though 1 should be enough (first the text, then the rest of the object).
When I start the print, the printer does the bed leveling, makes the first (cleaning?) squirt in the front left corner and asks for  change of filament, which I cannot skip, even if I have the correct one loaded. After the cleaning extrusion (which ask about the correct color), it touches at the end of the first cleaning line and directly proceed to print the object. First layer of object is printed, head comes for filament change, after which it goes back to the end of previous line, touches and then it goes to print first layer of the wipe tower and than prints the text. Same happens with the next filament change.
So my questions are:
  1. Why I need to add the M600? It already is in "Color change" section.
  2. Why I am asked to do 2 tool/filament changed (and in reality I have to do 3), even though one should be enough?
  3. Why I am asked for the initial filament change after the first squirt? And if so, why it does not print a cleaning line in the wipe tower?
  4. I did read some threads about the spots welded after the color change, but those suggested manual wipe towers. I understood that the issues were with older Slicer/firmware, but here slicer generates wipe tower on its own, but it doesn't use it as I would expect e.g. move head there after the color change.
  5. In the timers on the printer screen, there is an entry "Next change in" or something like this. But it is "N/A"; that would be actually very handy to see...
Sorry for lengthy novice post, I appreciate any suggestions, maybe I am just missing something as SW seems quite ready for this, but not quite...
Respondido : 12/01/2025 11:52 am
RE: Multi color print without MMU
I suspect you have the Main Body filament as extruder 1 and the text as extruder 2
the first filament change (After mesh bed levelling but before printing)  can be removed by editing Gcode, but the mk4 uses BGCODE and I don't know if  you can edit that.
the printer / slicer always uses filaments in the numerical order of the extruders,  so it might be better to set extruder 1 as the text colour and extruder 2 as the main body colour.
you are effectively mixing MMU functionality and manual colour change functionality.
the MMU Used to do mesh bed levelling, then load the filament to start printing, which I Believe is the cause of the first filament change,
I believe the second filament change is due to having the main body filament in extruder 1   (this can be resolved as mentioned above.)
and the third filament change, is the one you really want...  to change from test to body...
Respondido : 12/01/2025 12:27 pm
strjan
(@strjan)
@mmu: i see... Ok, that makes sense. I was thinking about starting the print with filament unloaded. (I'm not sure now, may be I even tried, but printer was not happy about it)
Is there other way, how to achieve it?
@extruder order: it was one of the first things I tried, but it seemed it didn't make a difference. Though, I haven't hit the print button, I was judging by reported tool swaps. I'll have another look.
My theory originally was that the slicer chooses to print big surface first to improve first layer adhesion, but than it starts with the intricate details of outside perimeters of the text....
Respondido : 12/01/2025 1:52 pm
strjan
(@strjan)
So great progress. I dont know where I was looking earlier, changing order of the extruders did the trick.
I have also added N parameter to the M600 command (both color and tool change sections), and it went immediately to the wipe tower after the filament change (e.g. no nozzle touches at the end of last track); but only the expected one. There is no wipe after the initial filament change. I think it is also the reason of the artifacts in the center of "a" in the picture below.
Is it worth rising an issue? Is this slicer, or printer problem?
Respondido : 12/01/2025 10:58 pm
Dante2201
(@dante2201)
Miembro
Hi Strjan, i followed the inputs you described... i have a similar challenge, and it works great except for two things.
1. You wrote in your last post, that you added the N Parameter to the tool & color change sections! How does this look like, meaning what do you write in it? just plain -N or something specific? M600 - N ? (Yes, the toolhead always travels to the last point of the printed piece, and only then moves to the wipe tower!
2. With two colors / extruders easy - with 3... haha, it turns into mayhem, as i never know which filament to load! I read somewhere, and i will dig a bit, that you can show which color to change in the display.
Thank you for your initial inputs, hope you can help me out!
Best regards!
Esta publicación ha sido modificada el hace 11 months por Dante2201
Respondido : 26/04/2025 10:44 am
strjan
(@strjan)
Have a look in this thread, there is nice description how to actually do it properly. And the printer will even tell you, which colour is next: https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-how-do-i-print-this/how-to-print-multi-material-models-without-an-mmu-tutorial/#post-734746
Respondido : 06/05/2025 5:18 pm
1 les gusta
