Leaving gluestick residue on the plate - will this hurt PLA prints?
Hello all,
I have been printing a fair amount of petg on a smooth sheet. To prevent damage to the sheet, I glue stick the sheet. Works great.
When I switch back to PLA, I wash the sheet twice; once with water to remove the glue and once with IPA to do a final cleanup. Then I print in PLA.
Here is my question - would it cause any issues if I printed PLA with glue stick residue on the bed? I do NOT mean like, leftover bits of brim from a PETG print, that obviously would cause an issue. I mean just literally the glue stick "layer".
Thanks!
Best Answer by Diem:
PVA does reduce adhesion so the chance of a print coming loose is increased - it depends on the height and the area attached to the print sheet.
A quick workaround is to mark one side of the sheet (sharpie in the corner) and use one side for PLA and the other for PETG.
RE: Leaving gluestick residue on the plate - will this hurt PLA prints?
... that is an incredibly good idea. Thank for very much both for the info and the idea. 🙂
One of my Minis is literally printing right now on a sheet that had leftover glue from a previous print. COuldn't be bothered to take the sheet from my workshop to the kitchen sink, never had any issues with it but obviously YMMV.
