Layer banding/ripple/distinction/line at material boundaries (lots of material to less material)
ksawyerwsu
(@ksawyerwsu)
I don't know the best way to directly describe this, but as I'm printing models on the mk4 I see this banding effect as the print goes up the z axis.
The pictured example you can see horizontal lines that align with a transition between a thinner/less material later, and a larger one. I've also seen this on simple prints were say it's a cup with a 5mm thick base that transitions to open for the top portion. Right at the transition of the last layer on the 5mm base, I can see banding as it goes to the basically wall/perimeter type of layers.
I don't think this is purely a IS issue, as I'm pretty sure I was seeing this before switching to IS. But I do know that my mk3 was not doing this.
MK4, .4mm nozzle, PLA material, no enclosure.
Any thoughts from all the gurus out here?
Ce sujet a été modifié il y a 2 years par ksawyerwsu
Publié : 23/12/2023 6:35 am
Lanark
(@lanark)
Membre
RE: Layer banding/ripple/distinction/line at material boundaries (lots of material to less material)
Did you find anything ? I have the same problem, so if anyone has an idea I'm interested as well
Publié : 01/01/2024 5:06 pm
ksawyerwsu
(@ksawyerwsu)
Unfortunately I haven't found anything as of yet, other than if I'm printing multiple objects it seems to be a bit better. This is making me think it's like uneven temp cooling or something.
Publié : 05/01/2024 3:02 am
ksawyerwsu
(@ksawyerwsu)
Minor Update.
I got my mk3 to mk4 upgrade done. The second machine is producing the same result. I've tried all the different default layer height variants for the input shaper. I also had a friend of mine try a file on his machine and it had the same problem. He also tried the print with input shaping off, which improved the artifact, but it still persisted, just to a much lower degree.
I've also gone through and done a full re-tension of the X and Y belts to see if it has made a difference and I'm not seeing one. I'll probably try different filament temps or extrusion multipliers next.
Publié : 22/01/2024 4:58 am
