How to print a file on MK4 that is too tall?
BillR94
(@billr94)
I have a file I want to print but it is too tall for the printer. Is there software (or a way) to be able to cut (for lack of a better word) the part and print 2 shorter pieces to be glued back together?
Veröffentlicht : 11/12/2024 9:27 pm
JP Guitars
(@jp-guitars)
RE: How to print a file on MK4 that is too tall?
Prusa Slicer has a function to do this, you need to make sure you are in expert mode
Veröffentlicht : 11/12/2024 9:31 pm
Please read the knowledge base for the basics.  The specific tool is called the Cut tool https://help.prusa3d.com/article/cut-tool_1779
It is also capable of adding in various locating peg/hole/dovetail etc options to help you align the parts when it comes to gluing them back together.
Veröffentlicht : 11/12/2024 9:35 pm
Thomas Lynch
(@thomas-lynch)
You may have to lay it on its side or rotate it
Then you can slice it. Then you should have 2 pieces that can be put back together
Tom
Veröffentlicht : 11/12/2024 10:08 pm
BillR94
(@billr94)
ahhh....ok found it. Thank you
Veröffentlicht : 11/12/2024 10:18 pm
