How to eliminate strange pattern on spiral vase.
switch
(@switch)
On the left is a spiral vase printed with MK3S.  On the same vase on MK4.
close up
What I need is the old spiral (smooth) pattern.  How do I eliminate this strange texture and weird elongated spiral on the MK4?
Napsal : 23/04/2024 12:20 am
RE: How to eliminate strange pattern on spiral vase.
can you attach the project file   as a ZIP file
regards, Joan
Napsal : 23/04/2024 12:36 am
switch
(@switch)
Here's the project file.
BT-70 BT-70 Falcon Heavy V5 Landing Leg tube 250+230+200 RTP PLA
Napsal : 23/04/2024 12:44 am
switch
(@switch)
I contacted Prusa support and they said "I recommend loosening both trapezoid nuts on your printer's Z axis' threaded rods".  I did that and the prints are smoother, not perfect spirals but good enough for the part I'm printing.
Napsal : 04/06/2024 6:00 pm
Normally a Spiral Vase model is a solid, not a tube.
should this be printed Spiral Vase?
Napsal : 04/06/2024 10:43 pm
switch
(@switch)
This is literally a tube.  Part of a series of telescoping tubes.  Works fine with my MK3s.   Are you suggesting that I model these as solid cylinders in my CAD program and print those in Spiral Vase mode?  That never occurred to me but heck, why not?
Napsal : 05/06/2024 12:26 am
That is how Spiral Vase Mode is meant to work, and you will be able to set the extrusion width to match the wall thickness that you want
  Regards Joan
Napsal : 05/06/2024 5:54 am
