Y axis belt keeps slipping out of tensioner!
Michael Roth
(@michael-roth)
I bought a pre assembled MK4 back in January. All of a sudden the other day the Y axis belt slipped out of the tensioner. When I went to fix it I noticed that they forgot to put the screws in that are supposed to hold the belt in. I put some in and reassembled it and it worked fine for a print and then failed again. It's done this a third time now and I'm not sure what to do to fix it so if doesn't keep happening?!
I'm sure it doesn't help that I'm printing ASA mostly, in a Lack enclosure.
I'm about ready to glue them in, but I don't really want to because that'll make it extremely difficult to repair or anything later on.
Does anyone have any suggestions?
Thanks, Mike
Napsal : 06/05/2024 3:23 am
Eef
 Eef
(@eef)
RE: Y axis belt keeps slipping out of tensioner!
loctite?
Napsal : 06/05/2024 9:30 pm
Michael Roth
(@michael-roth)
I think it's the belt ends slipping out of the holders, so I'm not sure that loctite would really help. The screws that are supposed to pinch the belt in are still in place.
Napsal : 06/05/2024 9:39 pm
chmax
(@chmax)
probably silly of me to propose this, but since you bought it preassembled, isn't this a warranty case and should be addressed by prusa support?
Napsal : 07/05/2024 8:26 am
Michael Roth
(@michael-roth)
Good point. I did talk to them the first time but I thought I had it fixed. I'll get ahold of them again today.
Napsal : 07/05/2024 11:50 am
Michael Roth
(@michael-roth)
Their suggestion is to reprint it in ASA of course. I'll give it a try and hope that took hold together long enough.
Napsal : 08/05/2024 12:06 am
thomasfifer
(@thomasfifer)
How has the reprinted ASA tensioner been working for you? I'm having the same issue, also mainly printing ASA in an enclosure.
Napsal : 06/07/2024 5:08 pm
thomasfifer
(@thomasfifer)
I ended up jamming enough scrap plastic into the tensioner to hold it tight enough for one more print cycle. Replacement ASA parts appear to be working well after several prints (but it did take a couple weeks the issue showed up in the first place).
Napsal : 10/07/2024 2:21 am
vhubbard
(@vhubbard)
Printing your own part will  be stronger.   .2mm and 4 profiles I find is good.  4 profiles to keep the bolt holes from collapsing when bolts are tightened.  Helps prevent bolts from coming loose.
I found the screws that hold the adjusters to the Y axis can come loose also.    What I did in the end was convert to a solid mount for the Y axis belts and used another Y tensioner design
Napsal : 11/07/2024 2:52 pm
filipdimitrov.com
(@filipdimitrov-com)
Just for the record - same problem here 🙂
Napsal : 04/09/2024 7:45 am
