X-axis test shows 251. Is this a problem?
Watchmaker
(@watchmaker)
Is this a problem that's easily solved?
Opublikowany : 18/06/2023 4:44 am
Rwills
(@rwills)
RE: X-axis test shows 251. Is this a problem?
Got the same issue here. Belt tightness doesn't seem to change what that axis measures for me. Currently waiting on chat with Prusa Support
Opublikowany : 24/06/2023 9:02 pm
Witties3D
(@witties3d)
I had the same problem.
In my case the ty raps for the cable three on the back side were cut on the side and they should be on top
Opublikowany : 25/06/2023 4:48 am
Witties3D
(@witties3d)
I am sorry but I can not edit .
I ment the cable tree on the back of the extruder
Opublikowany : 25/06/2023 7:20 am
Wowa
 Wowa
(@wowa)
I had the same problem. I had to move the tape connection up and remove the cable cover. See photo.
Otherwise, it was 100% wrong with the X axis. After the adjustment, it was wrong once, and after lubricating the rod, it is now OK.
This post was modified 3 years temu by Wowa
Opublikowany : 16/07/2023 5:39 pm
