Torque screwdriver for nozzle tightening
Davebert
(@davebert)
I know most people just wing it when tightening nozzles especially with the TC nozzles and the V6 nozzle adapter but . . . for the people that actually use a torque wrench to accurately measure this, what kind did you use? Will an inexpensive one like this be ok or do I need to spend the big bucks?
https://www.amazon.com/VEVOR-Screwdriver-Increment-Magnetic-Function/dp/B0CBC7VSXJ?source=ps-sl-shoppingads-lpcontext&ref_=fplfs&smid=ATVPDKIKX0DER&th=1
Or are there any beam type or click type 1/4" drive versions that will work down to such low values accurately?  The torques spec for a Prusa standard nozzle is 1.5 Nm but is that the same spec for a TC nozzle on a V6 adapter?? The 1.5Nm setting is only 13.3 inch pounds so I am worried a cheap wrench won't even be accurate.
Thanks
edit: Just found this one that has possibilities:
https://www.amazon.com/VANPO-Digital-Display-Torque-Screwdriver/dp/B09YTS1Y6C/ref=asc_df_B09YTS1Y6C/?tag=hyprod-20&linkCode=df0&hvadid=647233196764&hvpos=&hvnetw=g&hvrand=13703876327154201892&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9011675&hvtargid=pla-1720683709825&mcid=bb3eabfd12363d26961a4e6ba08ec280&th=1
Ce sujet a été modifié il y a 2 years par Davebert
Publié : 18/02/2024 10:21 pm
JP Guitars
(@jp-guitars)
RE: Torque screwdriver for nozzle tightening
I use a Norbar 1-5Nm torque wrench, not cheap mind you.
Publié : 18/02/2024 10:25 pm
Davebert
(@davebert)
Thanks. I just found this:
https://www.sliceengineering.com/products/nozzle-torque-wrench-1-5-nm
Only problem is if you need more that 1.5Nm this won't help any. I am mainly referring to TC nozzles and V6 adapter leakage.
Publié : 18/02/2024 10:41 pm
Davebert
(@davebert)
Oh yeah, I also have some plated copper heat blocks coming in case that matters on the torque spec. 🙂
Publié : 18/02/2024 10:50 pm
Davebert
(@davebert)
Just a followup. I decided to buy a beam type torque wrench as it is simple and even if it does a little out of calibration, it would be shown on the dial and you could easily add or subtract the offset. I chose the one below although there are many different ones available to choose from, but this one goes from 0 - 9 NM so I can cover all the possible torque values I may need. I know you can 3D print a slipper type torque wrench but you need something to verify the accuracy. And the "T" type one setting clicker torque wrench options would cost more if you have to buy 2 or3 different ones and you still need to be able to check the calibration on them. Of course I will need to use a mirror to read it but I will mark the bottom side so I can see the values without a mirror. 🙂
https://www.amazon.com/dp/B00XKIIKOM?psc=1&ref=ppx_yo2ov_dt_b_product_details
Ce message a été modifié il y a 2 years par Davebert
Publié : 24/02/2024 1:57 pm
bapski
(@bapski)
that's what i have and seems to work(?)
Posted by: @davebert
MY MODELS AT PRINTABLES
Publié : 24/02/2024 2:54 pm
