Slic3r won't put supports for MK4 like it does for MK3
Oregongeek
(@oregongeek)
Fil4ment
(@fil4ment)
RE: Slic3r won't put supports for MK4 like it does for MK3
move the part in the slicer, +1mm on the Z axis?
This should put the part off in space, and tell the slicer that it MUST have support.
Otherwise, I'd try modeling my own support, in the CAD model, with a 0.1 or 0.2mm gap between the part and the support cylinder.
Opublikowany : 27/08/2023 7:27 pm
Oregongeek
(@oregongeek)
Slic3r just keeps putting it on the build plate.  This is frustrating that I can't print as easily as I can on my MK3.  I want to like this printer, but it has been nothing but frustration at this point.
Opublikowany : 27/08/2023 9:52 pm
Fil4ment
(@fil4ment)
Can you post the file, for us to experiment with? I have some ideas, but I need to poke at it.
Opublikowany : 28/08/2023 2:29 am
Fil4ment
(@fil4ment)
Messing with my slicer, I just remembered a useful setting: turn on a raft of a few layers, and that should force support everywhere.
You could also try a brim that is of the type: "inner brim only"
Opublikowany : 28/08/2023 2:35 am
René
(@rene-3)
Go to the Print Settings tab and under Raft, specify a number of layers.
Opublikowany : 28/08/2023 5:52 am
