Slic3r won't put supports for MK4 like it does for MK3
RE: Slic3r won't put supports for MK4 like it does for MK3
move the part in the slicer, +1mm on the Z axis?
This should put the part off in space, and tell the slicer that it MUST have support.
Otherwise, I'd try modeling my own support, in the CAD model, with a 0.1 or 0.2mm gap between the part and the support cylinder.
Slic3r just keeps putting it on the build plate. This is frustrating that I can't print as easily as I can on my MK3. I want to like this printer, but it has been nothing but frustration at this point.
Can you post the file, for us to experiment with? I have some ideas, but I need to poke at it.
Messing with my slicer, I just remembered a useful setting: turn on a raft of a few layers, and that should force support everywhere.
You could also try a brim that is of the type: "inner brim only"
MK4
MK3
