Silicon socks on MK4 firmware 5.0.1
After assembling my Prusa MK4 kit, I followed the self test. After passing every other test, the hot end heat test failed several times with the "test with sock on" setting. When I changed the setting to "test without sock" and physically removed the sock, it passed the test without any problems.
Publié : 13/11/2023 7:16 pm
Owens2303 a aimé
RE: Silicon socks on MK4 firmware 5.0.1
I had exactly the same problem with the same solution, on a recent build of the MK4 kit with 5.0.1.
Publié : 14/11/2023 5:42 am
sphxdr a aimé
