Printer reporting multiple errors after print but it prints fine?
graemesmith1960
(@graemesmith1960)
My Mk4 with MMU3 has been running flawlessly for a while but recently after every print it shows an error screen.  The message is something like "The printer has detected multiple load and unload errors.  Suggest you check your Nextruder Main Plate" and then gives a link to Prusa.io/mmu-care.  That page says nothing, just gives a description of the parts.
I've replaced the main plate a couple of times and re-run gearbox calibration and eventually all the calibration routines including the MMU3 feed sensor.  I'm still getting the error screen after every print.  No prints have failed at all and the machine is running very well - apart form ending the prints with the error screen!
Is there an error log anywhere?  I seem to remember the Mk3 having one but I haven't found the Mk4 one yet.
Posted : 27/05/2024 12:25 pm
Yasar
(@yasar)
RE: Printer reporting multiple errors after print but it prints fine?
I have the same error, I also took everything apart, there were a few thread remains in the nextruder... cleaned it, still the error.... MK$ --> Settings --> Hardware ---> MMU maintenance reset.... and now it continues...error is gone in INFO --> MMU statistics were 1000 filament discharges...
Posted : 30/05/2024 5:45 am
graemesmith1960
(@graemesmith1960)
Thanks.  I think mine was dirty Finda in the end.  I'd forgotten about the maintenance reset though!
Posted : 30/05/2024 7:43 am
graemesmith1960
(@graemesmith1960)
I should also have mentioned that in my version of the Firmware (6.0.1) it's now called Nextruder Maintenance Reminder.
Posted : 30/05/2024 7:59 am
Dave in TXK
(@dave-in-txk)
I have the exact same issue, but only since I just installed the 'stable' Firmware 6.0.2 yesterday.
Posted : 23/06/2024 1:57 am
oberkorn
(@oberkorn)
I am having this on my Mk3.5 and there is no menu option anywhere that I can see to clear the error.
Posted : 06/07/2024 4:58 am
rei
 rei
(@rei)
MK4 MMU3. Same issue. Prints come out just fine but the error is incessant. Had the problem since 6.0.2, on 6.0.3 now.
Posted : 19/07/2024 4:09 am
Philippe C
(@philippe-c-2)
Same issue, had problems with the MMU3, fixed them, but the message is recurring, at the end of each print, it asks me to go to prusa.io/mmu-care
Posted : 09/08/2024 9:55 am
GarHens
(@garhens)
I get the same error message on my MK35 after a successful print.  There were no load, unload issues with the filament. Everything was fine.  Using latest 6.0.4+14924 (3.0.3) firmware.  Searching all forums, and Google, returns only this relevant post, that has no solution for 3.x
Posted : 22/08/2024 3:54 am
Dave in TXK
(@dave-in-txk)
So has anyone talked to support about this - same error, only after installing 6.02.02 just released the last 2 days?
Posted : 25/08/2024 3:12 am
Cl@Gr3
(@clgr3)
Hi guys, read here:
https://github.com/prusa3d/Prusa-Firmware-Buddy/issues/4113
Scheduled to fix in the next releases
Happy printing
Posted : 29/08/2024 9:42 pm
