Printer isn't starting after firmware update
Bartist3D
(@bartist3d)
I have tried to update to the latest firmware. everything goes fine till it is stuck at what I think is the last step, I saw it did a verification, but then the last thing on the screen is the prusa logo, and the full progress bar, together with the firmware that was loaded.
I tried to put the firmware that was loaded before, it does the firmware flash, but is also stuck at that specific screen. What can I do?
Napsal : 02/03/2024 7:31 am
Kenneth Henderick
(@kenneth-henderick)
RE: Printer isn't starting after firmware update
Flash 5.1.0, that will most likely help you out. Also make sure that after it got flashed and the printer booted, you remove firmwares from the USB stick.
See https://github.com/prusa3d/Prusa-Firmware-Buddy/issues/3629
Napsal : 02/03/2024 11:52 am
