Print Quality in some sections of the print bed
Bastelay
(@bastelay)
Mitglied
Good Morning Community!
I have a quick question regarding a problem that arises when I print multiple identical parts. In some (let's say 2/10) parts of the job I'm repeatedly getting quality problems so that I can't use the results.
It seems like the nozzle dives into the last layer which also gives a slight sound when the extruder is at the problematic parts. The surface of the layer is subsequently rough and as a result worsens over the next layer until it somehow stops and goes back to normal at some point after 50 layers or so.
Parameters:
Printer MK4 (factory assembled) with enclosure
Nozzle: 0.4mm
Material: ASA (fresh/dry)
Input Shaper file
In this picture you can see the problem in the top left 2 parts, to some extent also in the top 3 left.
Any help pointing me to the right solution for those symptoms is highly appreciated!
Thanks!
Dieses Thema wurde geändert Vor 2 years 2 mal von Bastelay
Veröffentlicht : 28/06/2024 7:03 am
Bastelay
(@bastelay)
Mitglied
RE: Print Quality in some sections of the print bed
Anyone who has a speculation where the problem could be coming from?
Happy to run some tests to confirm a theory
Veröffentlicht : 01/07/2024 8:49 am
Bastelay
(@bastelay)
Mitglied
Ok, just to follow up on this - I found out by myself.
The reason was insufficient cooling. The remedy that worked was to force the cooling fan on all the time (which I thought was a No-No for ASA, but apparently it worked)
Veröffentlicht : 10/07/2024 6:58 am
