"Nozzle Cleaning Failed." Error
Page 9 / 9
Antimix
(@antimix)
RE: "Nozzle Cleaning Failed." Error
@cupu It happened to me when I did not care that during the probing phase that the filament was tensioned. 😓
You must have at least one loop of filament over the Nextruder so that it will never go in tension between the Nextruder and the spool during the probe phase.
If the filament is tensioned it could apply negative force and push up the Nextruder, fooling the pressure sensor, so that the Nextruder goes much more down and break the bed.
No idea of what happens when you have a MMU3 on the MK4. I don't have it, and since there is the PTFE tube in play over the Nextruder, I couldn't  say anything.
Posted : 20/07/2024 11:00 am
cupu
 cupu
(@cupu)
Hi @antimix,
That is good info. I apologize, I am not understanding some things (not my native language and so on) so just to be clear, you're saying that:
- In certain situations, if the filament is pulling up on the nextruder it can mess with the load cell (i.e. the loadcell is higher than normal or thinking it's higher but the nozzle is in the same place)
- What do you mean by having a loop of filament over the nextruder? Does that literally mean to have a loop to have extra slack so if the filament tightens up on the spool side then the loop takes that tension (gets "smaller") rather than pulling on the nextruder?
I have the clasic setup of the MK4 inside the prusa enclosure ; so the filament spool is on the top right of the enclosure, it feeds into a pfte tube that is guided to the ceiling of the enclosure and then drops down vertically to the nextruder. Do you think this setup is problematic?
later edit: since the  filament thread is pulled from the bottom/below of the spool, I guess there could be tension in it.
Thank you very much again!
This post was modified 1 year ago 3 times by cupu
Posted : 20/07/2024 11:06 am
Antimix
(@antimix)
@cupu here is a picture of the printer, where you can see the green filament that is not tensioned between the spool and the Nextruder, it is almost horizontal, so when the Nozzle goes down it could not pull up the Nextruder.
Regards
Posted : 20/07/2024 5:11 pm
cupu
 cupu
(@cupu)
Thank you @antimix, that makes sense!
Posted : 20/07/2024 6:17 pm
cupu
 cupu
(@cupu)
Hi again,
In addition to the discussion and good tips above, I've also visited this entry in the KB: https://help.prusa3d.com/article/nozzle-cleaning-failed-mk4-mk3-9_689429
After performing the last step:
Temporarily remove the hotend fan by removing the previously adjusted bolts. This will expose the heatsink/loadcell. Then, loosen very slightly the three bolts that hold the heatsink/loadcell in place.
I've recalibrated the loadcell and did 2 prints without any cleanup failure at all ; this has never happened before, I used to retry the cleanup process 4+ times before managing a print. It's not a lot of data but I "feel" like things have changed ; as I don't plan on printing anything else soon (if my parts that I just printed fit together) , I thought I'd update here.
Thanks again.
Posted : 31/07/2024 11:02 pm
Daniel
(@daniel-16)
In case it could be useful to anyone, I use 5kg spools and use some automated system between prints so I need to avoid manually correcting errors so it doesn't negate the automation. The filament tension issue is therefore a problem for me.
So, I modified the start gcode to "tug" on the filament before initiating important operations, to minimise the chances of a failure. Usually does the trick.
Relevant parts:
; Aggressive Z homing
G28 Z ; home Z axis quickly
G1 Z5 F6000 ; move up a bit to ensure it's clear
G28 Z ; home Z axis again to ensure accuracy
G1 Z0 F6000 ; ensure Z is at zero
G28 X Y ; home X and Y axes
; Aggressive tugs to ensure filament is not taut via toolhead movement
G1 Z40 F3000 ; move nozzle to a high position
G1 Z0 F2000 ; move nozzle to a low position quickly to ensure filament tug
G92 E0 ; reset extruder position
G1 E15 F300 ; prime the nozzle with a longer extrusion
G1 X250 E60 F600 ; one long purge line at 0.2mm layer height
Posted : 01/08/2024 12:23 pm
kamnxt
(@kamnxt)
Having the same issue here with a large spool of filament mounted directly above the printer. Tried adding a tug like @daniel-16 but it doesn't seem to be 100% reliable as sometimes it manages to think it has homed when it hasn't even touched the heatbed... Thinking of solving this with a long PTFE tube to keep the filament length constant when the X/Z axes are moving.
Posted : 03/09/2024 2:11 pm
Fulmir
(@fulmir)
Posted by: @cupu
Hi again,
Thanks again.
Just wanted to add that after having the issue be a persistent problem on my freshly upgraded printer this solved it for me.
Posted : 06/01/2025 3:46 am
Print_Fandango
(@print_fandango-2)
the core one is having the same issues. What is the fix for this? Prusa wants me to send this printer back, I am ready to do it and get a refund as this is nonsense.
Posted : 28/04/2025 7:16 pm
jaschanarveson
(@jaschanarveson)
This happened to me again on one of my school's Mk4 printers, and in frustration I just unplugged it and plugged it back in to simulate a power-outage: it picked up where it left off, and I could quickly pause it and do a manual filament change.
It worked!
It was very annoying and felt totally unnecessary, but it worked.
Posted : 03/05/2025 1:59 pm
Radon
(@radon)
Had issue where Nozzle Cleaning failed error was popping up because extruder was too high to even check the height and clean nozzle.
What fixed it was https://help.prusa3d.com/article/nozzle-cleaning-failed-mk4-mk3-9_689429 part where you loosen 2 bolts on fan and 3 bolts on extruder. I had it tightened only by finger strength and it was still too much. Loadcell was "hitting" something even tho there was nothing there because of the tightness and then nozzle cleaning in mid air failed.
I got my bolts to just touching or even loose point in the extruder and fan and it works fine now.
Posted : 08/05/2025 5:25 pm
martyvona
(@martyvona)
Though I've had many successful prints with my MK4S, I've now had two "bouts" of repeated nozzle cleaning failed errors, separated by months.  In both cases the resolution seems to have been to ensure the loadcell was behaving.  There doesn't seem to be a calibration routine for the loadcell.  There is an interactive "loadcell test" procedure in the firmware menus, but that didn't seem to be very helpful, and passed in both cases, even though I was getting repeated nozzle cleaning failures.  It also forces you to wait for a total nozzle cooldown so it takes time.
I found it perhaps more useful to navigate to the live sensor readouts portion of the firmware UI.  There you will see a continually updating live readout of the raw loadcell value.  With nothing touching the loadcell, it should be relatively stable.  Don't expect it to be absolutely unchanging, but it should hover around some value.  If it's not, then there is a good chance something is pushing or pulling or otherwise stressing the loadcell that shouldn't be.  In my case, the equilbrium value is about 5000, but I'm not sure if that's true in general.  Once you have established that equilibrium, push on the nozzle a bit (with something so you don't get burned).  The loadcell readings should go noticeably *down* while you are pushing, but then should return to the equilibrium they were in initially after you let go.
For example, I just installed a new hotend, and in the process it seems I was a bit too eager to tidy up the heater and thermocouple wires.  I pulled them up pretty tight and then I tucked them in in such a way that I think they were actually continually pulling up on the hotend, and that was causing the loadcell to drift.  Resolution was to just loosen them up a bit.
The last time I had repeated nozzle cleaning errors, I went through the procedure to make sure all the screws holding the loadcell assembly weren't too tight, and that seems to have resolved it in that case.
I also tried to find actual documentation for Prusa's nozzle cleaning routine.  I didn't find much.  The implementation appears to be here in the sourcecode.  It appears to be a variation of the mesh bed leveling routine that is customized to watch for valid probes at three successive locations.  I didn't study it that carefully yet to understand how it defines "valid", but I suspect the idea is something like each probe attempts multiple touches and sees if those agree sufficiently with each other.  Perhaps debris on the nozzle tends to interfere with that.
That routine gets triggered from a G29 P9 code in the printer start g-code.  You can see this G29 P9 in prusaslicer in the printer profile -> custom g-code -> start g-code window.  Since that's editable, the nuclear option to disable the nozzle cleaning routine should be to comment out that line (i.e. insert a semicolon before the G29).  I haven't tried this personally yet.  So far it seems like the nozzle cleaning failures have not actually been in error for me; in both cases the failures were actually because something was in fact wrong, though it wasn't with the nozzle cleanliness; it was with the loadcell, and it was better to resolve that than to kill the nozzle cleaning routine which was just the "messenger".
Posted : 23/11/2025 9:50 pm
lysynski
(@lysynski)
I never had this error until the latest firmware update (6.4.0+11974) now I get it almost every print, doesn't matter if auto-retract is on or off.  Any suggestions for solving this one, seems firmware related.
Posted : 28/12/2025 8:52 pm
Page 9 / 9
