Not enough memory
bcer960
(@bcer960)
Not enough memory
I tried to send a program via pc thru prusalink, but I keep getting the error "not enough memory" even though the file is only 700k. I tried a larger file (3500k) to see if the file was corupt, but I get the same message. Neither of these seem to me to be a large file. Any help would be appreciated.
I tried having the file on the desktop, and on the a USB. These are alll .bgcode files.
Prusa MK4 with input shaper, generated on prusa slicer 2.7.2+win64
Opublikowany : 04/01/2024 5:31 am
1 ludzie polubili
JP Guitars
(@jp-guitars)
RE: Not enough memory
The obvious thing to check is that the USB stick in the printer is not full
Opublikowany : 04/01/2024 10:12 am
1 ludzie polubili
bcer960
(@bcer960)
Ahhhh,
no where did it say that a USB stick had to e in the printer.  I will try that tonight
Opublikowany : 04/01/2024 2:29 pm
JP Guitars
(@jp-guitars)
Posted by: @bcer960
Well if it was a kit then in the instructions Chapter 8, section 3.
If it was pre-built then page 35 bullet point 1
Opublikowany : 04/01/2024 2:47 pm
bcer960
(@bcer960)
It was a kit, unfortunatly, chapter 8, section 3 is not talking about prusalink, but I apreciate your insites
Opublikowany : 04/01/2024 3:50 pm
bcer960
(@bcer960)
but I stand corrected, in step 9 of the setup for prusalink it does say there must be a USB in the printer.
It was late last night, I just missed it.....
Opublikowany : 04/01/2024 3:55 pm
JP Guitars
(@jp-guitars)
We've all done it. 😉
Opublikowany : 04/01/2024 4:18 pm
