Not enough free space on the printer
AmazingHorse
(@amazinghorse)
Hi all.
Got message in Prusa Connect on any file transfer to printer: "Not enough free space on the printer"
Original and 3th party usb sticks are empty and formatted to FAT32, single partition.
Saved *.bbf or *.bgcode not visible by printer, but usb stick visible by printer.
Mechanically usb port don't have any damage.
Printer grounded. Static electricity?
Opublikowany : 06/05/2025 6:57 pm
real.droop
(@real-droop)
RE: Not enough free space on the printer
Any solution? Same problem here.
Opublikowany : 28/06/2025 3:25 am
Opi Bættlebeard
(@opi-baettlebeard)
Any solution? Can't print anything now...
Opublikowany : 18/07/2025 5:01 am
Vectorious
(@vectorious)
I had the same problem. I took the flash drive out and installed it in my laptop and my laptop said the drive needed to be formatted. Which tells me something corrupted it. So I did a quick format to fat32 and it started working again when I reinstalled the flash drive to the printer.
Hope this helps.
Opublikowany : 03/08/2025 9:09 pm
