New MK4 Stringing and Step Gaps
Hello!
I finished putting together my MK4 this week and have had (mostly) success. However, I'm having stringing issues, and even some z seam gaps. I have tried the following filaments, all with default profile settings:
- Hatchbox PLA purple
- Hatchbox PLA gold
- Prusa PLA silver (provided with printer - see attached photo)
I have printed a temperature tower of the Hatchbox gold, and was able to reduce stringing that way (by reducing temp). However, I'm not sure this is the correct fix, as the default temp is default for a reason... Looking for advice. Thanks!
RE: New MK4 Stringing and Step Gaps
You're not the only one with this problem.
Hello!
- Hatchbox PLA gold
I came across this post after some more research. I believe I have the same issue and have contacted Prusa support. Thank you!
