MK4 Filament stuck again and again
jMack
(@jmack)
Printer: MK4
Purchased and built: Mid July, this year
Filament Printed: 5249g to date
Filament Used:  100% PLA (various types/sources)
I'm basically unable to print right now. Intermittently, I'll get a "filament stuck" error, where it'll push it out, I'll feed it back in, then sometimes it'll print.
I can hear a CLICK CLICK with the feeder having the issue pushing the filament through just before it goes to the "filament stuck" error.
With this much filament printed, should I expect the need to replace my print head already?  Curious....as this is what I was going to do to try and fix.
Publié : 08/12/2025 7:04 pm
jan.d.slay
(@jan-d-slay)
RE: MK4 Filament stuck again and again
When I got my new Prusa XL, I printed 2 kg of PLA in toolhead 1. Then I put the same filament in toolhead 2 and the same thing you described happened.
I then tightened the screws until the rattling at least decreased. I turned off the setting in the ‘Stuck filament detection’ menu.
Are you printing with 0.4 mm? How high is the heatsink temperature when the error occurs? What does the filament look like behind the idler? Is it deformed and compressed?
Publié : 09/12/2025 9:55 am
It might be a partial clog - do a cold pull.
Or the wrong extruder idler pressure - sometimes due to filament with out-of-spec diameter - tweak idler pressure until the grip is good but also check filament diameter with a micrometer (three places over a metre and average) and if wrong enter the true diameter in the slicer so that it can calculate the correct extrusion.  If it's been clicking for a while open the extruder and blow out any dust build-up.
Publié : 09/12/2025 12:29 pm
1 personnes ont aimé
jMack
(@jmack)
Great questions.
  • I'm printing at 0.2mm lifts
  • Temps are set at standard 230 deg. I tried raising this to 240 with no change.
  • The filiment just shows 'cuts' into it from the feeder. To me, it looks like the motor is unable to push the filament at all, so the grip appears solid to the filament. Meaning: not stripping the filament at all.
Publié : 09/12/2025 9:22 pm
jMack
(@jmack)
I also checked the filament diameter using a dial caliper and both were very consistently 1.74mm.
Publié : 09/12/2025 11:02 pm
jMack
(@jmack)
IMG_4429
my wife was shaking something in the kitchen at first, but you should be able to clearly hear the clicking when trying to load/purge filament.
Publié : 09/12/2025 11:09 pm
jMack
(@jmack)
I performed 2 cold pull procedures last night. Still have the clicking.
Publié : 10/12/2025 2:28 pm
jMack
(@jmack)
SOLVED
I installed a new "Hotend for Prusa I3 MK4/XL/Core One Print Head Heater Block 24V 40W Heating Cartridge Thermistor Extruder Kit Printhead with Extra 0.2MM 0.4MM 0.6MM Brass Nozzles Accessories"
Now she's printing like new. Think I should bring this up with the folks at Prusa? Having only gone through 5kg of filament on my first go seems light - according to a few friends of mine who have more experience at this than I.
Publié : 15/12/2025 2:09 am
