MK4 Factory Assembled - Bad Bearings?
Page 1 / 5
Jeremy
(@jeremy-3)
Received my new MK4 and notice what sounds like a bad bearing.  Anybody else with similar issue?  If so, did you get support?  I'm in the queue of over 54 minutes...
Video attached with sound...
IMG_2075
Posted : 16/04/2023 7:34 pm
Hello
(@hello)
RE: MK4 Factory Assembled - Bad Bearings?
Somebody couple days ago had the same problem and they got replacement bearing if you can I recommend in about 2 hours it will be less wait time
Posted : 16/04/2023 8:02 pm
Jeremy liked
Hello
(@hello)
Chat time aren't to bad now also turn volume up and you will get alerted while you do something else
Posted : 16/04/2023 8:12 pm
Jeremy
(@jeremy-3)
Yeah, it's down to 17 minutes.  Thanks.
Posted : 16/04/2023 8:13 pm
Hello
(@hello)
Please let us know how it goes
Posted : 16/04/2023 9:21 pm
Jeremy
(@jeremy-3)
Support claims it's a loose screw somewhere, which is BS.  I checked every screw and bolt on the thing and no issues.  Here is a much better video of the sound...
IMG_2080
Posted : 18/04/2023 2:35 pm
iftibashir
(@iftibashir)
Almost sounds like something rubbing on the fan?
Open the fan door and make sure all the wires are tucked in securely…..
EDIT - just realised it can’t be that since the fan in enclosed on that side anyways…… just sounds like a vibration from something loose….
Click here for Original Prusa VIDEO BUILD GUIDES
--> MK4 - MK4S - MINI+ - Accelerometer Guide <--
Posted : 18/04/2023 4:12 pm
Jeremy
(@jeremy-3)
Going to re-check everything under the bend when the current print ends later.
Posted : 18/04/2023 4:29 pm
Dariusz Konopka
(@dariusz-konopka)
check out these two quick access hotend mounting screws
Posted : 18/04/2023 4:32 pm
iftibashir
(@iftibashir)
Saw a video on YouTube where someone had a noise - he tightened both Hotend thumb screws and the noise went away…..
Posted : 18/04/2023 6:50 pm
Jeremy
(@jeremy-3)
Found a M3 bolt that was missing on the Y axis but fixing that didn't do anything.  I've checked every single joint, contact point, screw, etc and the noise persists.  As you can see/hear it's only on the left side of the bed.
https://youtube.com/shorts/dtYscg-frOo
Posted : 19/04/2023 5:36 pm
iftibashir
(@iftibashir)
I’m not sure what to suggest but am awfully intrigued as to what this could be!! Hopefully someone more knowledgeable then me will chime in with some suggestions!
Posted : 19/04/2023 6:46 pm
ManelTo
(@manelto)
is there the same sound if you turn off the fans?
Sorry for my poor English. I try to do my best.
Posted : 19/04/2023 6:57 pm
Jeremy
(@jeremy-3)
Yeah, fans aren't the culprit.
I just got done degreasing and packing the y-axis bed bearings and no change in noise - still loud as ever in the same motions.
Posted : 19/04/2023 8:57 pm
Jeremy
(@jeremy-3)
I'm now questioning the X axis as the only remaining culprit.
Posted : 19/04/2023 9:07 pm
Jeremy
(@jeremy-3)
Update 5: In contact with support and this is their current response as I'm not the only one experiencing the issue...
our developers are currently looking into what can be causing these issues. While the final solution is still in the works, I can recommend following steps to mitigate the issue:
  • check the belt tension
  • increase printing speed by ~20%
  • try changing tension on these screws holding the X bearings some more, there is a high likelihood of finding a sweet spot where vibrations are minimal
Posted : 19/04/2023 11:12 pm
ScottW
(@scottw)
Posted by: @jeremy-3
I hope there's a better solution than that before they build/ship my MK4!  That noise is unacceptable, and playing about with speed, belt tension, and screw torque in pursuit of "...finding a sweet spot..." is not what I signed up for when buying a factory-assembled, factory-tested printer.
It does not seem that all MK4 units have this issue (or maybe they do, and others just haven't hit the right speeds/movements that exhibit it).  In any case, Prusa is pretty good at finding solutions and providing fix procedures -- so I sure hope they will come up with a standard solution for this soon.
Posted : 19/04/2023 11:30 pm
Jeremy
(@jeremy-3)
You can see in the attached that when you remove the small bottom plate, there is nothing retaining the bearings.  I can slide those bottom bearings out of the toolhead and do a X movement right or left and still get the noise.  So it's either the top third bearing (can't tighten/loosen it per say) or something with the housing itself.
Posted : 19/04/2023 11:38 pm
Jeremy
(@jeremy-3)
Update 7: Support has confirmed this to be a design flaw, of which they do not currently have a solution or a fix or an ETA. They do not know if using the machine as-is would do harm to the Nextruder or other toolhead components. The noise has gotten louder and there are noticeable artifacts on the prints.
This after completely tearing down and rebuilding the toolhead, reseating the bearings, trying pads under the bearings, etc.  It isn't the bearings themselves that are bad, unfortunately.
Posted : 20/04/2023 12:57 am
dp250f
(@dp250f)
Mine did this the first print out of the box. I traced the noise to the power supply and on inspection, it was the toroidal inductor (there's only one in the one I have) making the noise due to vibrations caused by very specific stepper motor speeds. I stuck a small piece of silicone tubing between it and the transformer next to it and that has prevented that vibration and stopped the noise.
Standard disclaimer - I don't recommend anyone take apart their power supply.
Posted : 20/04/2023 5:18 am
Page 1 / 5
