Massive Layer Shift on MK4
Phil
 Phil
(@phil-13)
Hi everyone,
I have an issue with a my most recent prints. I have tried printing it about 8 times and every time have a massive layer shift. Not just a tiny shift due to an issue with the belt. I'm talking of a 1-2cm shift (see images). Previously the printer printed fine.
I have tried many things to resolve the issue but without any success:
  • rechecked x+y belt tension
  • recalibrated x+y axis
  • cleaned nozzle
  • re-sliced model
  • used different infill patterns
  • reduced printer speed to 50%
I'd appreciate any hint or tips, as I don't know what the actual problem could be. I don't think it is a physical shift of the print, as the printing plate is still well in position after failure.
My printer also has a MMU.
Thanks a lot and best regards,
Phil
Napsal : 16/09/2024 10:04 am
Colin T
(@colin-t)
RE: Massive Layer Shift on MK4
Unfortunately, I too have exactly the same problem.
No problems at all when running as a straight MK4, but after I added the MMU3 and updated the firmware, I get a massive layer shift, always in the X axis.  It happens about one in every 3 or 4 prints.
I am running prusa3d_fw_MK4_MK4S_MK39_MK39S_6_1_3.bbf.
The image shows 2 failed attempts at printing these 2 pieces.
Napsal : 08/10/2024 5:07 pm
Stairman77
(@stairman77)
I also have this problem.  I have the problem on multiple prints and on multiple MK4 printers and on my XL (no MMUs).  I am wondering if it is the memory sticks, the bgcode file format, or my mac.  Keen to hear if anyone has solved this problem.
Napsal : 27/10/2024 2:36 am
alias23b
(@alias23b)
Yes, I have the same issue, mostly with boxes.  It is a recent occurrence, only the last month or two.  Models that printed with no issue before, are now having issues.
With the boxes, at best, I now have a seam at the top layer of the bottom.  At worst, a huge offset.
To be honest, I don't think there is anything that can be done on our end until Prusa releases a fix.
Napsal : 12/12/2024 1:15 am
Ayeoheee
(@ayeoheee)
Happening to me now also, after checking all belt tensions etc and of course this is only happening after 5 of the 6 hours of the print is done and its a massive shift. I just disabled IS and am trying a third. I'd like to send Prusa a bill for the 10 hours and filament I just wasted lol.
Napsal : 30/11/2025 7:49 pm
