M601 position override
sseibold
(@sseibold)
Hi all,
I am trying to print a box with magnets inserted. Due to the box being large and printed open with an in-place hinge, the locations where magnets require to be inserted end up at the 4 corners of the print bed. This renders the defaultM601 parking position (right, rear and too low) unusable.
Reprap Wiki show the M601 to accept parameters, but for me this does not seem to work on the Prusa MK4 .
I added M601 X130 Y210 Z170 S1 to the "Start G-code" in PrusaSlicer to save a different position for this print, but this just caused the printer to pause at it's default position before print. So it seemt to not only ignore the S1 but the positional parameters as well. With that, I cannot even issue a customized M601 during the print then.
Am I doing something wrong? Are the parameters to M601 not supported by MK4? Any ideas?
This topic was modified 1 year temu by sseibold
Opublikowany : 13/01/2025 10:42 am
Jesse
(@jesse-6)
I'm having a similar issue.  I need to insert some magnets near the corner of the bed, and I need space to access the print.  AFAICT all parameters to M601 are simply being ignored, despite what Prusa's docuementation says. I tried setting the park location with S at the start of the print, and also replacing the pauses with custom gcode saying M601 Z250  (which I think ought to work).
Is this a bug?  A bug in the documentation?  Am I just doing it wrong?
[ETA: this is on a Prusa XL]
This post was modified 10 months temu by Jesse
Opublikowany : 22/07/2025 1:42 am
