I can't compile MK4 firmware
Stránka 1 / 2
Juan Puchol
(@juan-puchol)
Hello, I need help. When I try to compile MK4 firmware I get (firmware 5.0.0-alpha4 compiles ok, but since this version is not working):
PS C:\Caribou320_Firmware\MK4\Prusa-Firmware-Buddy-5.0.1> python utils/build.py --preset mk4 --generate-bbf
Switching to Buddy's virtual environment.
You can disable this by defining BUDDY_NO_VIRTUALENV env. variable.
Traceback (most recent call last):
File "C:\Caribou320_Firmware\MK4\Prusa-Firmware-Buddy-5.0.1\utils\build.py", line 832, in <module> main()
File "C:\Caribou320_Firmware\MK4\Prusa-Firmware-Buddy-5.0.1\utils\build.py", line 623, in main bootstrap.switch_to_venv_if_nedded()
File "C:\Caribou320_Firmware\MK4\Prusa-Firmware-Buddy-5.0.1\utils\bootstrap.py", line 202, in switch_to_venv_if_nedded os.execv(str(venv_bin_dir / 'python'),FileNotFoundError: [Errno 2] No such file or directory
Napsal : 22/10/2023 7:37 pm
Giorgio91
(@giorgio91)
RE: I can't compile MK4 firmware
did you manage to solve it? I have the same problem
Posted by: @juan-pucholdid you manage to solve it? I have the same problem
Napsal : 18/11/2023 7:04 pm
David D.
(@david-d-2)
Hello, i have the same issue...
Napsal : 28/11/2023 1:49 pm
Smutje
(@smutje)
Same here. Did anyone solve the issue?
Prusa git:(master) ✗ python utils/build.py --preset mk4 --generate-bbf
You can disable this by setting the BUDDY_NO_VIRTUALENV=1 env. variable.
  File "/Users/Sebastian/Prusa/utils/build.py", line 832, in <module>
    main()
  File "/Users/Sebastian/Prusa/utils/build.py", line 623, in main
  File "/Users/Sebastian/Prusa/utils/bootstrap.py", line 211, in switch_to_venv_if_nedded
Napsal : 11/12/2023 9:26 pm
opened a bug report on github: https://github.com/prusa3d/Prusa-Firmware-Buddy/issues/3579
wbr,
Karl
Napsal : 12/12/2023 12:49 am
Github - bkerler commented Dec 12, 2023
It's easy to fix. install virtualenv, then do a python -m venv .venv in the git directory and it will work just fine using the build script.
wbr,
Karl
Napsal : 12/12/2023 10:58 am
Giorgio91
(@giorgio91)
I managed to solve it by installing version 3.11 of Python, with 3.12 it doesn't work for me.
Napsal : 12/12/2023 1:10 pm
Juan Puchol
(@juan-puchol)
Hello,
from firmware 5.0.0-alpha4 (that compiles fine) I copy the folders .venv and .dependencies to the new firmware folder and then it compiles well
Happy printing!!
Juan
Napsal : 12/12/2023 1:33 pm
I tried the compilation process on an ARM64 system - no chance.
On an x86/x64 system compile should work after .venv and. dependencies have been added.
wbr,
Karl
Napsal : 12/12/2023 1:48 pm
Closed the bugreport on github, because problem solved!
wbr,
Karl
Napsal : 12/12/2023 2:56 pm
Smutje
(@smutje)
Now it also works for me (Mac M1).
So, now since I am able to change some settings in the firmware (I want to disable Z_SAFE_HOMING), I can finally compile my own firmware.
Unfortunately the commands for the compelling are not well documented.
This is the basic command:
python3 utils/build.py --preset mk4 --generate-bbf
Prusa is using this (as mentioned on GitHub):
python3 utils/build.py --preset mk4 --build-type release --bootloader yes --generate-bbf --generate-dfu --no-store-output --version-suffix=-BETA+5729.PR3570.B5 --version-suffix-short=-BETA+5729 -DCUSTOM_COMPILE_OPTIONS:STRING=-Werror -DDEVELOPMENT_ITEMS_ENABLED:BOOL=yes
I wonder which of these settings are eventually necessary to compile a correct firmware
Napsal : 12/12/2023 8:11 pm
I have added an alias in ~/.bashrc:
alias python='/usr/bin/python3'
This allows you to start the compilation process as follows:
wbr,
Karl
Napsal : 12/12/2023 8:35 pm
GB
 GB
(@gb-3)
I have my firmware folder in C:\Users\Y\Desktop\3D Printers\Edited_Mini_Firmware\Prusa-Firmware-Buddy-5.1.2
(Simply the unzipped source code with a few edits in config)
After installing virtualenv and running a "python -m venv .venv" in the same directory, I keep getting this error upon the command "python utils/build.py --preset mini --generate-bbf":
C:\Users\Y\Desktop\3D Printers\Edited_Mini_Firmware\Prusa-Firmware-Buddy-5.1.2>python utils/build.py --preset mini --generate-bbf
C:\Users\Y\Desktop\3D Printers\Edited_Mini_Firmware\Prusa-Firmware-Buddy-5.1.2>C:\Users\Y\AppData\Local\Programs\Python\Python311\python.exe: can't open file 'C:\\Users\\Y\\Desktop\\3D Printers\\Edited_Mini_Firmware\\Prusa-Firmware-Buddy-5.1.2\\Printers\\Edited_Mini_Firmware\\Prusa-Firmware-Buddy-5.1.2\\.venv\\Scripts\\python': [Errno 2] No such file or directory
Doing something wrong?
Napsal : 19/01/2024 12:34 am
GB
 GB
(@gb-3)
Bumping. I'm not owed an answer, but I still would like to say that from being able to flash without any troube to, getting all this errors (and the documentation page hasn't been updated since) seems like a downgrade. Editing the Marlin config shouldn't be reserved to software developer - level skill.
Napsal : 21/01/2024 9:22 pm
1 lidem se líbí
LarGriff
(@largriff)
Still trying to compile.  No luck, do far.
2022 - Creality Ender 3 V2
2024 - Prusa MK4S/MMU3
2026 - Bambu P2S/AMS2Pro
Napsal : 18/03/2025 6:31 am
Juan Puchol
(@juan-puchol)
Please remove: --generate-bbf (it is not supported anymore) and try it
Napsal : 18/03/2025 8:42 am
LarGriff
(@largriff)
I tried it without the —generate-bbf and lots of other options.  Still not getting any satisfaction.
Napsal : 19/03/2025 12:45 pm
miroslav.h4
(@miroslav-h4)
When we talk about building and compiling FW for MK4. I only tried to translate the FW downloaded from Github without any modifications. The build failed. I used the command to build:  python utils/build.py --preset MK4 2> errors.txt 1> out.txt. How it turned out is captured in the attached file. There are two files in the zip: Out.txt is stdout from the command, and the errors.txt file captures the error output of the command. Can someone more professionally knowledgeable take a look at it and tell me where I'm making a mistake?
Napsal : 19/03/2025 3:28 pm
Juan Puchol
(@juan-puchol)
Please try:
and copy .dependencies from an older firmware.
I usually copy .vnvn adn .dependencies from an older firmware.
Bye
Napsal : 20/03/2025 6:32 pm
Juan Puchol
(@juan-puchol)
Please try:
I usually copy .venv and .dependencies from an older firmware.
Bye
Napsal : 20/03/2025 6:41 pm
Stránka 1 / 2
