How do I read bgcode files
I'm suspecting an issue in the bgcode file. (Print is failing on the same layer). Is their a way to covert bgcode files to gcode so I can analyze the gcode at the layer where the failure is occurring?
Best Answer by Per S.:
You can use PrusaSlicer v2.7 or later and convert between ascii and binary gcode. On Mac (I guess it's the same on Windows), under the File-menu, select Convert and from the sub-menu what direction you want to go.
Napsal : 02/01/2024 6:48 pm
RE: How do I read bgcode files
Napsal : 02/01/2024 8:40 pm
1 lidem se líbí
Also in Configuration > Preferences > Other, there is an option to disable bgcode if you want to export just gcode.
Napsal : 04/01/2024 3:37 pm
