[Solved] Hot end fan test fail
Altruego
(@altruego)
Was going through the calibration of my MK4.  Everything is ok except it is failing the hot end RPM test.  The fan is spinning and I have reset the connector in the Love board multiple times. Any ideas on what could be causing this and how to resolve?
Napsal : 27/11/2023 5:49 pm
Altruego
(@altruego)
RE: Hot end fan test fail
Forgot to mention I also checked for pinched cables
Napsal : 27/11/2023 5:59 pm
LilyPink
(@lilypink)
Judging by the other errors of recent since the update, i'd assume that atm...   no response yet to the issue below on failed Y calibration...  I've found a fudge, but i;m still having issues with TPU now,  extruder clicking and jamming, only since update...   so hopefully a new version will be release very soon !!
Napsal : 27/11/2023 6:42 pm
DrNick
(@drnick)
I had the same problem. Have you tried loosening the hot end fan screws a little? That worked for me.
Napsal : 27/11/2023 7:19 pm
Glen
 Glen
(@glen)
Zoinks!!!!  That worked for me....curious why literally just a tiny tiny tiny bit less tight mattered.
Thanks for posting!
Napsal : 04/01/2024 3:46 am
