Firmware 4.6.1 - Mk3 gcode
Ian Harris
(@ian-harris)
Anyone tried the Mk3 gcode compatability in the Mk4?
Does it work? Is it any faster in the Mk4 as against the Mk3?
Ian
Publié : 07/05/2023 9:32 am
Does it work?
We were told it was left out of the release version as an oversight and that it is tested and due to be available at the next firmware update.  Well, this is it.  Why not try it?
I doubt it, the gcode contains specific speed and move instructions so if they are set for a Mk3 they will run at Mk3 speeds.
Reslicing for Mk4 will be faster - on a Mk4, but will not run on a Mk3.
Cheero,
Publié : 07/05/2023 12:06 pm
