Filament needs help entering Nextruder tube
vanerie
(@vanerie)
Seems every time I change filament I need to open the door and manually (with needle nose pliers) guide into and shove filament down the tube.  ** It actually appears to get hung up on the lip of the metal tube.**      Is there an adjustment I need to make or should I replace with the "modified idler lever"?
Publié : 16/01/2024 3:00 pm
