Filament needs help entering Nextruder tube
Seems every time I change filament I need to open the door and manually (with needle nose pliers) guide into and shove filament down the tube. ** It actually appears to get hung up on the lip of the metal tube.** Is there an adjustment I need to make or should I replace with the "modified idler lever"?
Napsal : 16/01/2024 3:00 pm
