Extruder Position Load/Unload/Change Filament
ralfiboy1
(@ralfiboy1)
Hi guys,
I'd like to automatically move the extruder to a fixed postition for changing filament in order to drop the extruded waste-fila into the right hand side bin. Y-Axis with sheet all the way back, x-axis to the very right. Is there any chance of setting this fix somewhere in FW?
thx,  Ralf
Publié : 25/05/2024 1:13 pm
Not in firmware unless you fork from the GitHub sources.
But there is provision for this sort of personalisation in PrusaSlicer; PrinterSettings > Custom G-code  provides space for your additional code to be inserted at many significant stages - including before and after changes.
This becomes part of a new printer profile and will be inserted every time that profile is used.
Publié : 25/05/2024 3:59 pm
ralfiboy1
(@ralfiboy1)
RE: Extruder Position Load/Unload/Change Filament
Thx @diem, suppose I better leave FW alone than. Need to get into G-code instead and try. No trouble deleting profiles if I screw it up, I guess.
Regards,  Ralf
Publié : 25/05/2024 4:47 pm
