Connection refused error from PrusaLink?
RoboMan
(@roboman)
I followed every step, the printer is connected to Wifi, and I can also access it using Prusa Connect with no issues. When I try Prusalink (using the IP address on the browser), I get a connection refused error.
The same error when I added the physical printer to the slicer using API key I got from the Prusa Connect settings page.
I am using Chrom+Windows.
Any ideas?
Veröffentlicht : 03/06/2023 1:04 pm
RE: Connection refused error from PrusaLink?
Did you try http instead of https?
Veröffentlicht : 03/06/2023 3:21 pm
RoboMan
(@roboman)
Yes, I tried that, disabled the local firewall, and even disabled PrusaConnect, just in case.
Nothing helped.
Veröffentlicht : 03/06/2023 3:43 pm
RoboMan
(@roboman)
Okay, it started working, a few times reset, the wifdi module update, and it made it work (somehow).
Veröffentlicht : 03/06/2023 6:15 pm
noswall
(@noswall)
I had the same problem. It turns out that Enabled was set to Off in the Prusalink menu.
Veröffentlicht : 14/08/2023 9:04 am
