Clogged Nextruder Nozzle Adapter? o0
Alveon
(@alveon)
Hey guys,
title says it. I had a print fail due to clogging on Friday. I was printing with Extrudr GreenTech Pro Carbon at 225 °C on a hardened Zodiac 0.4 mm nozzle. Never had any issues with this filament, nozzle or setup.
Naturally I thought the nozzle itself was clogged from a fiber knot in the filament or something, printing CF on 0.4 mm is pushing it a little as I understand.
However, after disassembly I discovered the following:
The nozzle had been covered with a thin layer of cold plastic, that was now sticking out of the adapter. Looked like a piece of filament, but was basically a very brittle, thin tube, that broke away when I touched it.
This layer though stretches about 10 mm into the adapter, covering the inside with a thin layer of material.
Any idea of this might have happened and, more importantly, how to clean this up without messing up the adapter?
Ralf
Opublikowany : 06/08/2023 8:12 am
1 ludzie polubili
