Bad Thermistor in Hotend?
Job
 Job
(@job)
Miembro
When I start up my MK4 the live temperature reading for the hot end reads around 22o °C, while the hot end is room temperature and it stays room temp when I attempt to preheat the system for printing with PETG.
Is this a bad thermistor that needs to be replaced or is there some other trouble shooting I can attempt? This is pre-built system less than year old.
Respondido : 30/04/2026 8:13 pm
RE: Bad Thermistor in Hotend?
Shine a hot hair drier on the  hot end see if the temperature changes, if it does, the chances are your thermistor is good,
when you instruct the hot end to heat, does the hot end temperature change? If not the heater is probably disconnected from the socket or faulty...
it could be a broken wire on the heater itself or in the wiring bundle between the controller and the buddyboard, or faulty connectors... or the heater block may be faulty.....    Worst case, the Mosfet on the controller board may be faulty...
Respondido : 30/04/2026 8:45 pm
1 les gusta
Job
 Job
(@job)
Miembro
I'm pretty sure the heater isn't cutting on because the hotend temperature reading is erroneously >220°C at room temperature.
Respondido : 04/05/2026 3:24 pm
sorry I initially read the value as 22C   not 22oc
220C suggests that the thermistor circuit is low resistance, worthwhile changing the thermistor,
220C is not low enough resistance for a shortcircuit.
If you unplug the thermistor, the display temperature should go below 15C and give you a mintemp error... if it doesn't, suspect a controller issue.
Good luck
Joan
Respondido : 04/05/2026 3:53 pm
Job
 Job
(@job)
Miembro
Per your suggestion I unplugged the thermistor and the temp reading dropped to 0°C so yeah it looks thankfully it  look like a bad thermistor and not a controller issue.
Respondido : 04/05/2026 7:32 pm
Good news!
best wishes.
Joan
Respondido : 05/05/2026 12:09 am
Neverdie156
(@neverdie156)
I have the exact same problem. After replacing the thermistor, it's still the same. With the thermistor connected, it's 160°C, but without it, it's 40°C (room temperature is 20°C).
Respondido : 10/05/2026 5:19 am
Neverdie156
(@neverdie156)
I solved my problem — I replaced the LoveBoard and everything works as it should.
Respondido : 06/06/2026 6:10 am
1 les gusta
