y axis shift and missed layers
mep67
(@mep67)
Hey peeps,
I'm having and issue printing wing sections for an RC plane using colorfabb LW PLA. It appears that the printer is randomly not printing a layer which causes a slight shift and poor adhesion. I thought it might be the LW PLA foaming in the nozzle, but have turned off retractions. Happens at higher flow rates also.
I also am having issues with y axis layer shift. I'm not sure if the two might be related. Layer skipping happens with wing oriented along x axis (in order to minimize y axis shift) also. I increased temp without improvement and other layers seem to be fused together well.
general settings are:
temp 235, flow 0.51-0.6, speed 23mm/s, retract 0, layer 0.3, lift 0.1
Thanks
Postato : 10/05/2024 5:17 pm
mep67
(@mep67)
RE: y axis shift and missed layers
I forgot to add that I've,
checked belt tension, checked for obstructions to y axis, checked grub screws on y axis drive gear, checked for smooth movement of bearings and print bed
Postato : 10/05/2024 5:28 pm
