XBuddy Board assembly issue
buntschu30
(@buntschu30)
Hey i have a XBuddy Board assembly issue.
I couldn't mount a screw correctly on the housing and the thread broke. While I had to pull out the screw with the pliers (after 2 hours...) I scratched the xBuddy a bit... the housing is damaged too. I was very disappointed about it. Now I dont know yet if i broked it 🙁 but now the screw is out... I'm going to finish my assembly and need to test if everything is ok... I don't know which function is broke now. (The number of the broken part is c186, as you can see on the picture)
I will be getting from Prusa a new housing and I still have to test the xbuddy board first.
Does someone can help me and already know if its a big damage or not?
Thanks for the support
Napsal : 11/05/2024 12:17 pm
buntschu30
(@buntschu30)
This red light comes on at the beginning when i switch the machine on. Is it due to this resistor that has fallen out? The heating tests are successfully.
Who can help me?
This post was modified před 2 years by buntschu30
Napsal : 13/05/2024 7:53 pm
Oregun
(@oregun)
RE: XBuddy Board assembly issue
C186 is a capacitor and looks to be part of the mmu circuitry but it probably isn't a good thing to be missing. Here is a link to the schematics, bring up the buddy pdf an search for C186.
https://www.prusa3d.com/downloads/Electronics_drawings/MK4_electronics_schematics.zip
Napsal : 13/05/2024 11:30 pm
Oregun
(@oregun)
Actually, looking here https://help.prusa3d.com/article/xbuddy-status-leds-mk4-mk3-9_532438 at the leds it's either a current fault or a heater fault (I can't tell from the photo).
Napsal : 13/05/2024 11:35 pm
buntschu30
(@buntschu30)
Thank you so much for your help:)
So now I have 2 problems? The first problem with the MMU circuitry, the circuit without a compensator and the second problem a heater error? Heating tests are still working successfully… idk whats the issue here.
In the pdf’s i found the circuit of the missing compensator… so what is the effect of this missing part? I dont really understand these things. Can you explain me?
here a screenshot
here a we-transfer link of the screenshot for better quality: https://we.tl/t-RmsLI3J1ky
thank you for helping me
Napsal : 14/05/2024 12:08 am
Hello
(@hello)
Posted by: @buntschu30
Who can help me?
Have you tried prusa support live chat and told theme about the red light and you think the board is faulty, if from a photo of the whole board you dont see damage prusa support will send a new one under warrenty
Napsal : 14/05/2024 10:02 am
buntschu30
(@buntschu30)
yes i have already contacted them they will reply to me. If this red light is a big problem because of the missing compensator then i need to get a replacement of the board.
Napsal : 14/05/2024 4:39 pm
