Official useful life expectancy of MK4
Getahobbie
(@getahobbie)
Is there an official (from Prusa) estimate of number of hours a printer should last.  I was hoping to write off the depreciation off my machines on my taxes.  All the numbers I've seen online are anecdotal.
I realize that with maintenance and repairs it should last indefinitely but maybe the main board has a number of hours that it's rated for.
Opublikowany : 12/03/2025 2:42 am
DPerez
(@dperez)
RE: Official useful life expectancy of MK4
Any luck?
Opublikowany : 07/04/2026 12:41 am
Same Old Shane
(@same-old-shane)
Member Admin
Unfortunately there are so many different factors when it comes to a printers life span. For example a well maintained printer using PLA / PETG would last longer than a non maintained printer printing ASA in hot temps. Plus when you take how often the printer is running, along with other factors.
If you wanted to try and figure out a cost to add for wear and tear / maintenance, over on the Prusa calculator,
https://blog.prusa3d.com/3d-printing-price-calculator_38905/
I believe its set to estimated money you will put into repair and upkeep on your printer.
Shane (AKA FromPrusa)
Opublikowany : 07/04/2026 4:06 am
