MK4 to Idaho
BID3D
(@bid3d)
MK4 to Idaho
New MK4 kit ordered.  Looking at the map, first one in Idaho USA. (??)
Any other new MK4 builders/users nearby?
Veröffentlicht : 07/11/2023 11:45 pm
ForbiddenPhoton
(@forbiddenphoton)
RE: MK4 to Idaho
I know this thread's a bit dated, but MK4 user here in Boise.  I've had my MK4 since May and I've put 2,082 print hours on it thus far.
I hope your MK4 is working great for you!
Veröffentlicht : 08/11/2023 8:19 pm
BID3D
(@bid3d)
RE: MK4 to Idaho
Cool. Good to know. Have you worn out any parts ?
Veröffentlicht : 08/11/2023 8:30 pm
iftibashir
(@iftibashir)
Takes a lot of heavy use to wear out parts IMO, especially if just using as a hobby and not in a 24/7 running print farm scenario....
Did you get the kit or assembled?
EDIT: Ignore, you mentioned kit in the first post! Have fun building!
Veröffentlicht : 09/11/2023 3:00 pm
ForbiddenPhoton
(@forbiddenphoton)
RE: MK4 to Idaho
I haven't worn out any parts that aren't typical wear parts.  Surprisingly, the belts are holding tension pretty well.  I've gone through a few nozzles though, which is a bummer with their per unit cost plus shipping from Prusa overseas.  I've been doing some large volume prints with PolyTerra PLA and I find the matte fibers cause more wear than I had expected.  I really ought to snag one of the V6 adapters or the ObXidian nozzle.
Veröffentlicht : 10/11/2023 1:03 am
BID3D
(@bid3d)
RE: MK4 to Idaho
https://www.printedsolid.com
Maybe a cheaper source for nozzles, versus paying  international shipping costs
Veröffentlicht : 10/11/2023 1:10 am
ForbiddenPhoton
(@forbiddenphoton)
RE: MK4 to Idaho
I placed an order with Printed Solid a while ago and had a great experience.  At the time I don't believe they had Nextruder nozzles in-stock.  I'm sure the nozzles will make their way over in due time.
How's your MK4 holding up?  Have you had much success with the 5.0.0 Input Shaping functionality?
Veröffentlicht : 11/11/2023 10:43 pm
BID3D
(@bid3d)
RE: MK4 to Idaho
MK4 kit is on order, due in a couple weeks. I was reading earlier today about IS and the various capabilities and PrusaSlicer settings...
intend to use it....stay tuned
Veröffentlicht : 12/11/2023 1:22 am
ForbiddenPhoton
(@forbiddenphoton)
RE: MK4 to Idaho
I look forward to hearing how your kit build goes.  Mine has been a great workhorse for pretty much whatever I want to print.
Unfortunately, I haven't had a lot of success with IS yet.  For applications where appearance isn't essential, it seems to work pretty well and shave off a significant chunk of time.  However, if appearance is paramount I forgo IS almost entirely.  I've noticed prints with IS have weird angled ring-like artifacts in the corners.  Below is a photo of the same print done with IS enabled (top) and disabled (bottom) and compared side-by-side.  These were both printed with the 5.0.0 stable firmware since the 5.1.0-alpha2 is causing me trouble.  Hopefully future firmware will help iron out some of these kinks.
Veröffentlicht : 16/11/2023 1:34 am
