MK4 Manual Colour Change Problem
Ian
 Ian
(@ian-7)
Hello,
I'm trying to Print this Bunny with a black body and white head and set a colour change at 48.60mm, after re-slicing the colour change is not recognised in slicer or the printer.
Any ideas why? (It works correctly when auto sensing a colour change)
Thanks
Ian
Este debate ha sido modificado el hace 2 years 2 veces por Ian
Respondido : 09/06/2024 6:28 am
RE: MK4 Manual Colour Change Problem
Add a copy of your project file for us to look at please.
Respondido : 09/06/2024 8:38 am
Ian
 Ian
(@ian-7)
Bunny Colour Change.3mf
Thanks
Respondido : 09/06/2024 8:51 am
Here are two possible options
Black n White Bunny 1
the file above uses standard layer height colourchange and is currently set for PETG
Black n White Bunny 2 PLA
this option uses virtual extruders and height range modifiers to change the filament
this file is currently set to PLA
Respondido : 09/06/2024 9:11 am
Hi Ian,
something odd seems to be happening with your project file,
when the model slices it shows the two colour model as would be expected, then the image changes to a single colour image
After slicing
I changed the filament colour in the right hand window and the image changed
and asked me to re slice the file,
and I got this (All Blue, Again)
have you actually tried printing to see what happens?
Respondido : 09/06/2024 9:37 am
Ian
 Ian
(@ian-7)
"have you actually tried printing to see what happens?"
Yes, but the printer doesn't recognise the filament change.
My printer recognises your "Black n White Bunny 1" filament change, did you do anything else after clicking on the layer height to apply a colour change?
Respondido : 09/06/2024 9:52 am
Hi Ian,
After selecting height to make colour change, I also changed the colour for the two sections to make it more representative.
Respondido : 09/06/2024 7:31 pm
Ian
 Ian
(@ian-7)
Hello Joan,
I think it could something with this STL as I made a name tag with the name raised and the colour change was recognised.
Regards Ian
Respondido : 10/06/2024 1:00 pm
