Mid layer skips, this is getting really annoying!
André Lind
(@andre-lind)
I've been getting these really weird and extremely annoying mid-layer skips on both of my MK4s
Everything is going fine until it suddenly skips 50-150 lines of GCODE and then resumes further along
And when I print the exact same file again it works...
Napsal : 19/02/2024 6:46 pm
Dakyleman
(@dakyleman)
RE: Mid layer skips, this is getting really annoying!
Are you printing via USB stick, WiFi, or serial?
Napsal : 19/02/2024 8:06 pm
miroslav.h4
(@miroslav-h4)
I would try replacing the USB stick with a different one and try the prints again. It looks like a time-out while reading. The new USB stick can only have printable files, not necessarily the contents of the original USB.
This post was modified před 2 years by miroslav.h4
Napsal : 19/02/2024 8:21 pm
André Lind
(@andre-lind)
Replaced the stick on both machines but still get missing extrusions completely random...
Printing via Prusa Connect, also tried disabling binary GCODE and right now I'll try to downgrade the firmware
Napsal : 05/03/2024 12:57 pm
Mike B
(@mike-b-3)
It appears that the printer is skipping gcode but continuing on correctly afterwards, correct?  That eliminates axis shifts, and you appear to have eliminated USB stick issues.  I'm thinking what's left is software issues (not the slicer since it doesn't happen consistently for the same file), or hardware issues in the main control board (buddy board?) or display board, or maybe the parallel cable to the display board (although I'd expect crashes if that was the case).  But I'd start with the parallel cable - replace it or reseat it and see if anything changes...  maybe that cable only carries print data and the addresses are getting corrupted occasionally?  Does your display glitch at all?  I'm just guessing here without fully understanding how the printer really works under the covers.
If your firmware version was the issue this would be seen by more people since presumably thousands of people are using the same firmware.
Napsal : 05/03/2024 5:09 pm
André Lind
(@andre-lind)
Yeah, it skips something like 70-150 lines of gcode and then continues on as if nothing had happened :-/
If it happens during infill its not a big deal but sometimes its top layers or outer perimeters...
I have 2 MK4:s, one factory assembled and one from a kit. Both printers have the same issue so thinking its either something in the firmware or enviromental
Have downgraded both machines to 5.0.1 now and have not hooked them up to Prusa Connect
If this works out I'll try to upgrade them again to 5.1.2 without PC to see if they are more stable then
Napsal : 05/03/2024 5:54 pm
kbauchert
(@kbauchert)
I'm having the same exact problem, except I have two MK3.9 printers.  Both printers do this, both are totally random, sometimes they skip a section, most of the time they don't, even when printing the same exact file that's been stored on the USB stick.  The layer number, location, and length of section that's skipped also seems totally random.  I've seen this happen with my own eyes, it's printing along just fine then suddenly the extruder jumps forward to a different part of the layer, or moves to the next layer and starts printing away again.  There's no error message, nor anything garbled on the display.  The printer does not seem to know it just randomly skipped part of the GCODE.  Very annoying because it completely ruins the print as the next layer won't stick, then it creates a big globby mess.
Napsal : 16/01/2025 8:15 pm
