Calibrating nozzle temperature
HowardHo
(@howardho)
The thermister wires on the nozzle broke so I got a new one.  The prints are now coming out poorly with unevenly deposited layers and stringy. I think the nozzle temperature is the culprit.   Using a temperature probe the temp measures about 1/2 of what it should when measure at the surface of the nozzle.  I can't find where the nozzle temperature is calibrated.
So how do I calibrate the nozzle temperature?  Is it even possible?
Thanks in advance.
Posted : 20/06/2025 12:33 am
Robin_13
(@robin_13)
RE: Calibrating nozzle temperature
From the error, sounds like the wrong value thermistor.  It is calibrated through the resistance.  If you have an ohmmeter, and you can get a connection on the old resistor, compare the cold resistance, the readings should be very close.
Posted : 26/06/2025 11:59 pm
