Before buying the MK4...
YigalB
(@yigalb-2)
Hi All
Few questions before I purchase MK4, to be the 2nd printer next to the good old Prusa Mini, mostly to be used with PLA:
1- The sizes are 50x55x40 c"m. So just to be sure: 50 is the width, 55 is the depth, and 40 is the height. Is that correct?
2- If 52 cm is the width I have, would it be OK also from future maintenance point of view?
3- What is recommended to purchase with the printer? Another sheet? Nozzle? Any replacement parts that will be needed sooner or later?
4- I used beagle camera to control my Prusa mini. Works well. Any recommendation what to use with the MK4? (Sadly Prusa doesn't recommend such a solution, not providing one as well)
Thank you
Respondido : 12/05/2024 12:22 pm
JP Guitars
(@jp-guitars)
RE: Before buying the MK4...
I'm no where near my printer so can check sizes, but for the other questions
3. Get a Satin Sheet, works for most filament unlike the standard smooth sheet; https://help.prusa3d.com/materials
4. ESP32CAM, dirt cheap and just works, below is my enclosure for it but there are a few other options. The page includes details of the software I use.
https://www.printables.com/model/668369-esp32-cam-case-and-mount-for-mk4
Respondido : 12/05/2024 1:56 pm
2 les gusta
YigalB
(@yigalb-2)
Posted by: @jp-guitars
Thanks for the Satin sheet info. I will.
As for the ESP32 cam - sounds good to me, especially since I have such a CAMs from my ESP32 projects.
Just to make sure I got it right: This CAM is connected to a separate ESP32, not to the one installed inside the MK4. So it would need a power supply (5V through the USB connector? ). Is that correct?
Respondido : 12/05/2024 3:12 pm
JP Guitars
(@jp-guitars)
Yes, it is independent of the printer, I've got mine running form a burst bucker to step down the power supply voltage to 5v so it gets switch with the printer. I bought a ESP32-Cam and a ESP32-Cam-MB as it is the easiest, it's about a fiver from China or 10ish from Amazon/Ebay
Respondido : 12/05/2024 3:34 pm
1 les gusta
Zappes
(@zappes)
As far as nozzles go, getting an Obxidian nozzle would be a terrific idea if you plan to print any abrasive filaments such as PC Blend Carbon.
My models on Printables
Respondido : 13/05/2024 8:55 am
1 les gusta
efvee
(@efvee)
Add a set of the these silicone sockets to your purchase.
Respondido : 13/05/2024 1:15 pm
1 les gusta
YigalB
(@yigalb-2)
Posted by: @efvee
What silicone sockets??
Respondido : 13/05/2024 1:43 pm
Walter Layher
(@walter-layher)
I think what he meant were those socks: https://www.prusa3d.com/de/produkt/prusa-nextruder-silicone-sock-set/
Respondido : 13/05/2024 2:47 pm
1 les gusta
iftibashir
(@iftibashir)
Where are you based?
I have spare LevenDig silicone socks for the MK4.......
Respondido : 21/05/2024 5:55 pm
1 les gusta
YigalB
(@yigalb-2)
Posted by: @iftibashir
Thank you!
I already ordered the MK4 with the silicones.. hoping to get it this week.
Respondido : 22/05/2024 4:54 am
1 les gusta
