4.6.2 Firmware for Original Prusa MK4
Same Old Shane
(@same-old-shane)
Member Admin
Hello all;
Here is our latest update to the MK4 firmware. These address some parts of the self test.
Summary
  • Adjustments to the Selftest
Note: this release is focused on the MK4 and has no effect on the XL.
The Selftest procedure was adjusted for this release, specifically the speed of movements on the X/Y-axes and the sensitivity of the stallguard.
There is no need to re-run the selftest, if your printer is already successfully calibrated.
Download firmware here;
github.com/prusa3d/Prusa-Firmware-Buddy/releases/tag/v4.6.2
To update the firmware;
Copy the firmware file (.bbf) onto the USB drive with FAT32 formatting Insert the flash drive in the MK4's USB port Turn the printer ON (or reboot it) A new screen will appear Confirm you want to flash the firmware
Shane (AKA FromPrusa)
Napsal : 17/05/2023 4:35 am
Aquaerics
(@aquaerics)
RE: 4.6.2 Firmware for Original Prusa MK4
4.6.4 is now availabel:
https://github.com/prusa3d/Prusa-Firmware-Buddy/releases/tag/v4.6.4
Napsal : 13/06/2023 11:11 am
1 lidem se líbí
