Selftest - Heatbed failed - help needed
MartinD
(@martind)
Just build my first MK4, after selftest I got "Failed result"
Failed is the part with headbed heating, - I noticed it want to heat it up to 110celsius, but heat it quite slowly - and heat it up to 60-65 celsius during the test - meaning test fails.
Any helps what I did wrong, or what should I check?
The  bed is heating for sure, but for some reason not as quick as test wants.
Dieses Thema wurde geändert Vor 3 years von MartinD
Veröffentlicht : 13/07/2023 9:38 am
Thejiral
(@thejiral)
RE: Selftest - Heatbed failed - help needed
A stupid question from my side. Have you tried the self-test a second time? Did it fail again and reach exactly the same temperature as before (60-65°C)?
Veröffentlicht : 13/07/2023 12:41 pm
MartinD
(@martind)
 Yep, I run it multiple times, the same result - the test is heating heatbed, but not quick enough to get 110celsius, and ends with fail, temperature vary (but usually between 60-70 celsius)
Posted by: @thejiral
Diese r Beitrag wurde geändert Vor 3 years von MartinD
Veröffentlicht : 13/07/2023 12:45 pm
Thejiral
(@thejiral)
Odd. Maybe someone else knows more but I would stop the time, how long it is actually trying to heat, until it skips, and then contact Prusa Live chat about that issue.
Veröffentlicht : 13/07/2023 1:02 pm
Walter Layher
(@walter-layher)
I don't know if this is the first time you assembled a printer and how much experience you have in this subject, so forgive me if this sounds like a silly question. 🙂
Did you check that all wire connections between PSU, electronics box and heat bed were made exactly as shown in the instructions, that they are secure and have good contact?
I remember a posting where somebody attached the wires to the wrong side of the heat bed and the connector cover deformed because of the heat caused by the bad contact.
Veröffentlicht : 13/07/2023 2:25 pm
DRACO
(@draco)
Mitglied
Hi MartinD,
Which steel sheet did you use for calibration/selftest ?
Ive got the same ettot with the textured sheet ... but when I swapped to the smooth sheet the calibration worked like a charm.
Tested several times: With textured sheets i had 6 fails out of 6 tests.
With smooth sheet 4 out of 4 sucessfull tests.
Seems that the textured sheet has slihltly different thermal capacity - and my MK4 couldnt handle the difference
Posted by: @martind
Veröffentlicht : 20/07/2023 4:28 pm
XSImnl
(@xsimnl)
Mitglied
Can confirm that..
Textured sheet - Multiple fails
Satin sheet - Failed
Smooth sheet - Passed on 1st try
Veröffentlicht : 20/08/2023 1:58 pm
Nickbaxter
(@nickbaxter)
Mitglied
I can confirm…
No sheet - failed
Smooth sheet - pass
Unacceptable for Prusa to not make this clear. Hours wasted…
Veröffentlicht : 10/01/2024 1:36 am
Mohammed
(@mohammed-2)
Mitglied
This Worked
Veröffentlicht : 19/01/2024 6:36 pm
Dmitri K
(@dmitri-k)
Mitglied
Posted by: @nickbaxter
I can confirm…
No sheet - failed
Smooth sheet - pass
Glad I found this thread, was changing nozzle so took the sheet off and had constant fails, i usually do a check just in case, with a sheet it passed, not sure why this is not part of instructions of calibration... thankfully i came across this thread 30 minuts after driving myself nuts with the issue.
Veröffentlicht : 14/03/2024 10:19 am
screamnAbdab
(@screamnabdab)
My experience may be of some value.
I had several failures with texture sheet and no sheet at all. Turned off the LED light bar ( https://www.printables.com/model/3267-led-light-bar-prusa-i3-mk2mk3) and the test passed. Maybe just a coincidence.
Veröffentlicht : 15/05/2024 7:20 pm
Herbie
(@herbie)
Thank you  XSImnl and Nick
This worked saved me a lot of headaches
Veröffentlicht : 03/06/2024 5:12 pm
terrorent
(@terrorent)
Mitglied
Unfortunately, I get the same result no matter which sheet I use.  Does anyone know what the test is looking for as the pass/fail criteria?  Rise rate?  Final temperature?  Prusa support just told me to skip it and try to print (which works fine), but I need to get rid of this calibration nag warning.
Veröffentlicht : 18/07/2024 3:46 pm
