MK4 Loud noise while printing
Skint007
(@skint007)
I've printed 15 or so things since I first built my MK4, and during the last print which was a 15h long one, mid-way through it started making this horrible high-pitched noise. I'm not sure what is causing it, is it the extruder or one of the x/y axis?
Video
https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2023/08/30db7b1b-v_20230823_191554_es6.mp4
Napsal : 24/08/2023 2:42 am
1 lidem se líbí
Skint007
(@skint007)
RE: MK4 Loud noise while printing
Can't figure out how to edit my first post, but it appears my video didn't make it through.
Here is the video
https://photos.app.goo.gl/eorgqgum6N6GBN959
Napsal : 28/08/2023 2:07 am
Hi Skint007,
From your first post, the link for the video had formatting information surrounding it, which stopped the link displaying...
See below
I copied the video link and deleted the formatting information, and not the link shows in your first post.
My concern is that I Don't know where the formatting information comes from, as I don't get that problem, myself...
Weird...
Similar formatting information van stop images displaying, too.
Napsal : 28/08/2023 11:32 am
Sisyrx
(@sisyrx)
My MK4 just started to exhibit the exact same sound after 6 days of otherwise quiet printing!
Clip for reference: https://drive.google.com/file/d/1yzvyi5w-6A7P-VsvSxizXnC6jglOxmmR/view?usp=drivesdk
Napsal : 06/09/2023 4:38 am
The first quick and painless remedy to try is a little lubrication on the smooth rods.
Napsal : 06/09/2023 4:37 pm
Sisyrx
(@sisyrx)
Thanks for the suggestion!  My issue has been isolated to the idler lever as I can reproduce the issue by manually moving the E-axis with filament loaded and reproduce the sound.
Other users have suggested I reprint the part which I will do once I receive my PETG and textured plate.  I've tried disassembling and cleaning out the bearing pockets but no success yet.  The manufactured part appears to be poorly made/warped.
Posted by: @diem
Napsal : 06/09/2023 6:19 pm
Skint007
(@skint007)
In case it helps anyone, the issue for me was indeed the extruder. After needing to change filaments, I tried to unload it and the filament got stuck because it had a blob on the end. I ended up continually backing out the extruder by 5mm until I had it cleared and picked out any little pieces of filament along the way.
Napsal : 08/09/2023 2:53 am
1 lidem se líbí
Sisyrx
(@sisyrx)
Thanks for sharing your experience.  I did the same thing last night and found no real debris in the Nextruder gear so my issue persists.
I'm glad your printer is back to normal though!
Posted by: @skint007
Napsal : 08/09/2023 2:52 pm
