First Print went fine, then only failures
Icenor
(@icenor)
Utenti
Just assembled my upgraded MK4. I did my first test print, the keychain gcode file on the USB. It was perfect. But after that every print I do fails. Even the same keychain gcode print doesn't work any more.
On the second print it started to blob a little so I stopped the print. Is it possible I've got a clog already? I'll include some pictures of how the first layer looks:
https://ibb.co/nBzKMhX
https://ibb.co/t8Mqpp2
https://ibb.co/BCZ4fTG
Best Answer by David Bartel:
I did something really dumb and caused all kinds of problems. I put a sock on my nozzle then forgot to flip the idler lock back down. I'm just saying it wont hurt to double check the simple stuff.
Postato : 29/12/2023 8:10 am
David Bartel
(@david-bartel)
RE: First Print went fine, then only failures
Postato : 29/12/2023 4:05 pm
Icenor
(@icenor)
Utenti
I did as you suggested and it turned out the two screws holding the hot end had come lose after the first print. I tighten it and now it prints perfect again. I wonder if these screws will continue to come lose due to all the motion and vibration.
Anyways, thanks.
Postato : 30/12/2023 12:38 pm
